AutoCAD Forum
DWG to PDF to printer issues
4 REPLIES 4
coopdavillage
506 Views, 4 Replies
I have searched everywhere for this but can't find anything on it.
We are using the DWG to PDF pc3 to print all of our drawings. Everything comes out perfectly when we print to the PDF but when we send the PDF to certain printers (i.e. HP 5500) it is missing the shaded back lines.
This is not a CTB issue because it prints perfectly to PDF just not to the printer.
We have tested serever issues, updates and print drivers including firmware updates and nothing changes it.
When we use our PDF-XChange printer is comes out perfect no matter what printer the PDF is sent to. The PDF from the different printers also look exactly the same.
I have attached a test PDF from the DWG to PDF print.
Any ideas?
4 REPLIES 4
pendean
in reply to: coopdavillage
Win7 64bit? HP devices work best with HP's Universal Printer Driver (what we use with no issues): otherwise it looks like you already have a better PDF creator to use.
coopdavillage
in reply to: pendean
Win 7, 64 pro. We are using the Universal printer, have tried all versions that we can find. Its not the only printer having issues unfortunately.
I have tried all settings on the printers and the drivers and nothing works.
I know its the DWG to PDF print driver because the PDF-XChange driver does not have this problem. But I need some more definitive info for management and figured I would ask if anyone else has had the same issue.
pendean
Which AutoCAD version are you using?
Can you share the DWG file that created your PDF test file that you posted?
IMHO 3rd party PDF drivers are way better that Autodesk's offerings.
coopdavillage
We are currently using 2014 (C3D & Acad).
I have attached a test dwg that was created (not by me) to test universally.
The problem is the PDF's come out perfect, but when you print the DWG to PDF PDF to the printer is has issues with some printers.
The PDF-XChange printer does not. Its really odd.
Printing directly from cad to the printer has no issue either.
”Boost
