I created PDFs using autodesk's DWG to PDF plotter. I then combine the PDFs in acrobat XI, and they all appear fine. Perfectly centered. Once I send them to our wide format plotter, the first page prints correctly, but all the remaining pages are off center.
If I choose to print "current page" vs "all", and do this for each page of the pdf, they all come out fine. It's only when I choose to print them all at once that they become off-centered.
I'll post the same issue up on the acrobat forum, but I believe this may be related to the DWG to PDF plotter within autocad, because this issue doesn't occur with the adobe pdf plotter within autocad.
We are using autocad 2014
I'm having the exact same issue, except I am simply publishing from Autocad LT 2014 (or 2010) to create a multi-page PDF. It doesn't matter if I open it in Adobe or another program, it looks perfect but when I print the second and subsequent pages they are way off centre and chopped off. Did you find a solution?
