Printing and Plotting
Distinguished Contributor
Hammer.john.j
Message 21 of 42 (1,118 Views)
Re: dwg to pdf flattening process
09-22-2009 04:25 AM in reply to: *Greg Hubers
The layering can also be created because of linesmerge, not just drawing layers, fyi.
John Hammer, LA
Dell Precision T3500 - Xenon W3550 @ 3.07 (4 core)
Ram @ 12Gb
64bit Win7 Pro
Samsung SSD
NVIDIA Quadro 2000 - Dual Monitors
Cat 6 network with GlobalScape Avail Agent - WAFS
Infrastructure Design Suite Premium and Civil 3D 2012 & 2014
Valued Contributor
rmiller1973
Message 22 of 42 (1,118 Views)
02-12-2010 08:20 AM in reply to: *Greg Hubers
It looks like the line merge option does make Acrobat think there are layers. If you change the Advanced Printing option to print as Image (located within print dialog box) it by passes the flattening process. I'm not really sure if the printing process is slower compared to the dame file being plotted without layers and line merge.
Hopefully this is something that can be addressed in the next version of DWG to PDF ... we like having the option to merge lines (I wish AEC masking still worked with merged lines though).
Rob
*Expert Elite*
LeafRiders
Message 23 of 42 (838 Views)
03-31-2012 11:10 AM in reply to: rmiller1973
Whoever stated that PDFs aren't meant for printing and that it should be TIFF has no idea what you're talking about. PDF is the accepted plot format for many customers. The customer and the people using the software drive the market, not the other way around. What is DWF? It's nothing... it's PDF and Adobe and Autodesk need to sit down an hash out some common issues. I can't even send a 20 MB PDF to a HP plotter because it's "flattening" and then timing out. I've tried a lot of different things, but it's really pretty lame thus far. This feature clearly needs to be refined for 2013 etc.
*Expert Elite*
pendean
Message 24 of 42 (827 Views)
04-03-2012 05:25 AM in reply to: LeafRiders
"flattening" is when you, the user, set the PDF to have "levels": this is done when you decie to include your layer list, or turn on Overwrite feature in the PC3 file.
"flattening" in PDFs has been around forever, you can recreate it in Photoshop (yes, it has layers too) and any other high end graphics program from all vendors that offer "layers".
Paper prints are flat.
In Photoshop, you can and must "flatten" before creating the PDF to avoid the issue: you do the same in AutoCAD by turning off the features I noted above that you (or your CAD Manager, whomever is the one in control) turned on.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
*Expert Elite*
LeafRiders
Message 25 of 42 (824 Views)
04-03-2012 09:58 AM in reply to: pendean
So if that truely is the case, why do I turn these features "OFF" and still result in "flattening" at the time of printing the PDF? Is it issues with transparencies? I'm guessing transparency setting was a feature that was added to AutoCAD on a whim and is what ultimately has created issues plotting PDFs. Something isn't right with how AutoCAD prints files with aerial imagery, and transparencies. AutoCAD is a GIS / Mapping application the last time I checked. If multiple offices, clients, and print shops can't print a PDF generated from AutoCAD than the issue is with AutoCAD i'm affraid.
Maybe it's an issue with large image files, but I would trade 95% of every new feature introduced from R14 to 2012 for a product that could print to PDF without issues.
*Expert Elite*
pendean
Message 26 of 42 (830 Views)
04-05-2012 05:26 AM in reply to: LeafRiders
Yes, those add layers too: if you want to only use AutoCAD as an old-school drafting board (that would be R14 BTW), do so by never using all these features in your current AutoCAD. You can get R14 in your current version, it's not rocket science, you know exactly how to do it :smileyhappy:
Try a 3rd party "free" PDF driver if you don't want the featureset of the built-in PDF driver and almost all for-pay PDF drivers: most freeware PDF drivers totally ignore layers and layering (reason for the price), generate flat 2D PDFs all day long. Control of output is very limited, but that's all part of the price and the lack of features. Oh, and if you like the freeware you find, please do NOT buy it's for-purchase version, you will then get the featureset you want to avoid and we'll have to start all over again.
Member
ADGuzman81
Message 27 of 42 (667 Views)
04-17-2013 03:26 PM in reply to: LeafRiders
I have also read through this and other posts and changed the settings in batchplot publish print options as suggested, but am still getting the "flattening" when printing the PDF.
I agree that it must be AutoCAD's PDF converter that is causing the issue and not Adobe. Autodesk can certainly improve on this as it's a major effeciency issue and the workarounds stated in these posts just waste more time.
To compare: we mainly use MicroStation for 90% of our production work, due to state standards, and plotting the PDFs it creates (with or without level/layer information and images) is way smoother and requires no flattening. The PDF's themselves appear more clear on the screen as well.
To avoid CAD program bashing, let me say that both platforms have their strengths and room for improvement. With at least 5 years experience on each I can say that neither one is overall better than the other. They are both great products with a similar purpose, but with different approaches.
Nothing's impossible, just really, really hard.
Angel Guzman
*Expert Elite*
pendean
Message 28 of 42 (661 Views)
04-18-2013 05:19 AM in reply to: ADGuzman81
In the DWG to PDF.PC3 file, turn off Layer List creation and change from the Merge Control OverWrite feature: two features your Adobe driver does not do and why you don't see 'flattening' in PDFs created with Adobe drivers.
It's all about you creating the 'feature' and not turning it off: the two options are discussed in this thread and dozens of others related to this problem. You do the same in Adobe Photoshop/Illustrator to stop 'flattening' in PDF printing too.
Member
ADGuzman81
Message 29 of 42 (649 Views)
04-18-2013 07:16 AM in reply to: pendean
Thank you Dean,
The screen shots really helped. I had been changing those settings in Publish Options (Clip1 attached), but I guess it doesn't affect the PC3 file? I changed the settings (see Clip2 and Clip3 attached) as you showed and saved them to the DWG to PDF.PC3 file. Then I published my drawings with the updated PC3 file.
Maybe I missed something, but the resulting PDF still goes through 'flattening' when printing.
Please let me know of anything else I may have missed. I read in other threads that wipeouts may have something to do with this also, I do have some wipeouts in my drawings. Please help me figure this out.
Thanks again.
Angel G.
Angel Guzman
*Expert Elite*
pendean
Message 30 of 42 (638 Views)
04-18-2013 08:52 AM in reply to: ADGuzman81
Sorry, but I cannot replicate your issue here with any PDFs I've created using the DWG to PDF.PC3 file as noted above, printing in Adobe Acrobat 9 or Foxit Reader and any printer we have. Attached is a test file that worked fine too.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
