We just started in 2014 last week. When we batch plot to PDF using the DWG to PDF driver we get multi-page files no matter which is selected in the Publish Options. Has anyone else encountered this / found a fix to allow single sheet PDF creation?
Solved by M_Hensley. Go to Solution.
Solved by pendean. Go to Solution.
We are up to date with SP1. We have done it this same way for years. This was not the original job where we discovered the problem (different computer, different drawings) but same result: one file with 16 sheers.
halla-fricken-lullah!
i was going nuts with this too.....something must have chnaged with the settings in 2014, as i have been doing batch plots for years with no problems...then bam! all seperate sheets.
thanks for the post, i can stop crying now!!!
Thank you very much. The "plotter named in pagesetup" worked in 2013, so it just changed this version.
Part II - we just discovered that when we batch plot to PLT files, it also creates one file with multiple sheets. We would prefer to make each sheet a separate file. I believe that you are required to have a plotter setup to plot to file and that you must select "printer named in page setup" in order to do PLT files. Thus, we cannot duplicate the fix for PDF/DWFs. Any new thoughts about batch plotting to PLT plot files?
Maybe I wasn't clear about the issue. We are doing the same thing we have done for at least five years: batch plot to make PLT files. We know how to set up an AutoCAD pagesetup. Before, we would print individual sheets, i.e. M-1, M-2, M-3, etc., and the output would be M-1.plt, M-2.plt, M-3.plt, etc. Now it creates one file, called M-1.plt that contains three drawings. If you send it to the printer, three sheets come out. The issue is our Oce Printer Direct software will not separate out individual sheets, so if you need to reprint one, you have to do the whole set.
Yes, we do sometimes use PLT files because they are generally small and can be emailed easily if we send out our print job. Also, we have had issues in the past with many Excel sheets on a drawing and have had better success creating PLT files and converting to PDF. Perhaps that is less an issue in 2014, but it is the work around that we had to do because of software incompatibilities in the past and people like to use what they know will work.
I'm not sure we are on same wavelength here. I just want to know if we can do this or if it was purposefully changed and we have to adjust. We have always had a plotter setup to import for printing to PDF and PLT files. We cannot get the desired result using these in AutoCAD 2014, but by changing the Publish To: field in the Publish screen to PDF, we can get our desired result. They have options for DWF, DWFx and PDF. So we cannot select PLT there. Different people have tried numerous times to make a single sheet PLT file without success. So we have tested. And failed. So, can it be done or not? That, is the question.
Sorry if I reacted a little harshly. I know we oldsters can get in ruts, but calling our routine 1990 was a little severe. I mean, I have only been using AutoCAD since 1991!
Please test it on your end and find out: I don't have your plotter and I don't publish to PLT.
PLT is created by setting your plotter driver to output to file. If I set my plotter driver/PC3 file to output to file, I get single PLT files here.
Don't import an existing/old plotter setup if it doesn't work: test by creating a new one.
Love the 1991 comment 🙂
Does changing the PUBLISHCOLLATE value have any effect on printing to PLT?
using this configuration, how / where is the .ctb file specified to control lineweights of output?
