We have had a PDF based archive for quite a while but a new resource tool ( "ThinkWise" ... ) cannot work with PDF, or DWF or whatever the rest of the world uses and needs PNG. ( yes, it's really worth it's price š )
The batch plot utility of AutoCAD 2015 will only use the plotter named in page setup or PDF or DWF(x)
This means that we need to change the default printer in the page setups of all drawings in the archive to "PublishToWeb PNG.pc3".
Now, if I manually change the "DWG to PDF" plotter for the PNG one... the paper size is retained and a scale factor of 11.81 to 1 is automatically introduced.
If I use any form of batch script/lisp/vla to change multiple files... the scale factor does not come across... and all pictures become really small.
I need help to get the scale factor to be set as well... - if only because I will need to set it back to PDF automatically as well (including 1:1 scale) , because that is what the people expect it to print like...
( oh yes... and still: if anyone knows a better PNG printer then the one that comes with AutoCAD - I'd like to know about that one as well.)
I don't know about publishing to PNG, but what version of Acrobat have you got?
From at least Acrobat 9 onwards you can save a PDF as a PNG.
Howard Walker
