Windows 8.1 Pro, Autodesk BDSP 2015
This is the fourth pc being setup with all the same programs, features, etc. I have not personally set all of them up, but I did do one of them. Everything works fine on the others, but this one I am setting up now for some reason cannot find the network share locations.
I open ACAD2015 as administrator to install Heidi drivers for a KIP 3100 series plotter. Start the wizard, select the shared plotter form the server, select have disk, navigate to the location of the drivers on the network and select. Then I get error "The system cannot find the path specified." when it is trying to copy files over to the mapped drive path where the drivers and info are stored. Same set up on other pc's and it works fine. I did notice that on the other pc's it doesn't see the mapped F: drive either, but it can still copy to it. It's quite odd.
I have tried repairing, re-installing, and completely uninstalling ACAD2015- restarting the pc- reinstalling from BDSP- restarting again and then running, still with the same results. I'm at a loss as to what the issue could be. Probably something silly as usual with these things, but any input would be greatly appreciated!!
