AutoCAD Forum
Antialiasing added to AutoCAD 2015... but not to printers?
7 REPLIES 7
Message 1 of 8
1408 Views, 7 Replies
AutoCAD 2015 added antialiasing to the screen, giving us all "smooth lines" and all that...
But how do I print/export/save to a PNG (or other bitmap) with the same quality?
When I would (want to use) a screenshot... obviously it is antialiased when I have that switched on in 2015.. but that will also give me the entire AutoCAD interface, and no scaling etc.
When I use PNGOUT on a layout, I basically get a screenshot output... So, with 2015 antialiasing on, it seems to be kind of antialiased - but it also prints the paper's edge and seems to be unconfigurable (resolution etc).
When I use the Publishtoweb PNG plotter I get the configuring I'd like (output size etc)... but the output is aliased - blocky... pixelly.
The plotter is configurable... up to a point: the graphics section basically lets you pick color, black/white or ancient (256 color) - as long as it's 100 DPI.
Am I overlooking a setting, is there an updated .pc3 file available... do I need to wait till the next Acad release and hope the plotters then are updated to the screen possibilities?
7 REPLIES 7
Message 2 of 8
It doesn't really help either that the plot preview has antialiasing - while the plotter doesn't 😕
Message 3 of 8
pendean
Display settings have nothing to dow ith output: if you want what you see on screen in a file explore using a screen-capture tool.
Also, read this classic tip http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Underst...
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=1028
Message 4 of 8
in reply to: pendean
Yes... duh. I did think I covered both of those things in my question.
But from that I take it you do not have a real solution either...
So I'll just keep bothering Autodesk till they update the bitmap output pc3's 😛
Message 5 of 8
pendean
Sadly it's your last sentence in the first post forced a repeat of the solutions. You still appeared confused with your second post.
If you want Autodesk to listen, you need to get their attention here http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794 or report it as a bug here http://download.autodesk.com/us/support/report_a_bug.html and/or through your subscription webpage's 'contact us' link.
No one in this forum is taking notes for Autodesk developers unless it's by sheer accident.
Message 6 of 8
Sorry if it sounded confused... but I always first see if there's something I might be overlooking or doing wrong before I put it as a suggestion/bug.
The second post was more of a complaint: a preview should be exactly that, not a nice-ed up version.
Your two links are dead to me by the way, but I'll look around the site for where they've moved them.
Message 7 of 8
pendean
Both links work fine then and right now: you may be just having a local issue when you tried them (don't copy/paste them).
Message 8 of 8
Jup, they work now. When I jut tried them (by just clicking), I got the Autodesk site "sorry moved" page for one and a time-out for the other.
”Boost
