Please, add the union of bodies from each other at a distance of
Solved by romanov-kovrov. Go to Solution.
There is a function to ungroup the body, and it would be desirable to group the body
What do you mean exactly?
Darek
In PowerShape certain Booleans can create a single solid that is really two separate bodies. PowerShape has a tool to split such bodies into separate solids. What @romanov-kovrov wants is the ability to do the opposite, i.e. combine two solids that neither intersect nor touch into a single solid. I will pass this to development as a Wish.
