At the PowerMILL 2016 SP13.
I create the offset_area_clear toolpath.
I found the toolpath sequence was error.
How can I fixed this at PowerMILL 2016?
refer a video.
Solved by iamcdn79. Go to Solution.
Select the slice that starts at the bottom of the toolpath then click on the 'Reorder Toolpath' icon then click 'move to start'
Hey @hx
I cloned your original toolpath and expanded the block 10 mm in the X & Y then recalculated it. That seemed to fix the sequence order. Attached is the updated project.
