Does anyone know of a way to capture the parameter of a selected surface Z height, without changing the block, see screen shot below.
I can capture the information from by calculation the block to the model then using Block.Limits.ZMax, but would prefer not to mess with block.
Solved by Kevin.hammond2. Go to Solution.
I don't know of way to capture those values in a macro. The easiest way is, as you said, to calculate a block.
If you are worried about losing your block settings you could export the block at the beginning of the macro and re-import it at the end.
I know its not the most elegant solution but it should work.
Try this:
FORM BLOCK
EDIT BLOCK RESET
$Block.Limits.ZMin = round(Block.Limits.ZMin;2)
$Block.Limits.ZMax = round(Block.Limits.ZMax;2)
REAL $CALC_BLOCK_Z = round(Block.Limits.ZMax;2) - round(Block.Limits.ZMin;2)
MESSAGE INFO $CALC_BLOCK_Z
BLOCK CANCEL
EDIT MODEL ALL DESELECT ALL
BLOCK CANCELLED
Here you have another solution:
STRING filePath = "C:\surfPos.txt" DIALOGS MESSAGE OFF TRACEFILE OPEN $filePath SIZE MODEL TRACEFILE CLOSE DIALOGS MESSAGE ON STRING LIST $restOfFile = { } FILE OPEN $filePath FOR READ AS input FILE READ $restOfFile FROM input FILE CLOSE input STRING MinZPossition = trim(substring($restOfFile[5], 49, 20)) STRING MaxZPossition = trim(substring($restOfFile[6], 49, 20)) MESSAGE INFO "'Z' axis possition of selected surface." + CRLF + "Max.: " + $MaxZPossition + CRLF + "Min.: " + $MinZPossition
I hope it helps.
Mateusz
Thanks, for the replies guys.
Mateus, i think yours does what i need, i will test it out, thanks
Kevin
The following code should also work and does not require you to create a text file.
Real $Zmin = 0
Real $ZMax = 0
INT $Counter = 0
FOREACH $Mod IN folder('model') {
IF $Counter {
$Zmin = MIN($Zmin, LIMITS($Mod)[4])
$Zmax = MAX($Zmax, LIMITS($Mod)[5])
} ELSE {
$Zmin = LIMITS($Mod)[4]
$Zmax = LIMITS($Mod)[5]
$Counter = $Counter + 1
// Popup a dialog to inform user of the ZMin and ZMax
MESSAGE INFO "Z Maximum = $Zmax" + CRLF + "Z Minimum= $Zmin"
Here's where I ended up.
Creates a list of models in the session, prompts user to pick one, then capture it's Maximum Z.
The commented (//) out lines are just for reference and the message was just to test output.
Thanks for the assistance guys.
Regards Kevin
Real ZMax = 0
STRING LIST Models = {}
FOREACH mod IN folder('Model') {
int s = add_last(Models, mod.Name)
String pick = input choice $models "Get Max height from model - Pick MP"
string Modname = Models[$pick]
REAL ARRAY Lims[] = limits('model', $Modname)
//The values in the array are:
//REAL MinX = round(Lims[0], 3)
//REAL MaxX = round(Lims[1], 3)
//REAL MinY = round(Lims[2], 3)
//REAL MaxY = round(Lims[3], 3)
//REAL MinZ = round(Lims[4], 3)
REAL MaxZ = round(Lims[5], 3)
message info $Modname + " " + $MaxZ
