There are a few techniques that you can use to manage larger assemblies. Thanks to @Phil.E for the content of this tip!
VIEW
Section view analysis
Use a section view analysis to provide visual access with one click to an interior view.
Named views
Set named views to return to an area of focus with one click.
SELECTION
Selection sets
Create a selection set, this will be used to toggle visibility of many parts at once
When needed, pick the selection set.
Then right click in space to use Show/Hide
Results
Selection filter
Use this to help with window selections. Filter for Components, for instance.
Select Through
Use the Select Through setting to ensure that window selections can pick the hidden components.
BROWSER
Sub-Assemblies
Create logical subassemblies. The visibility can be toggled more easily.
Use in conjunction with Rigid Group. (see below)
Activate Component
Create all sketches, bodies, and components inside the subcomponent, rather than moving them there later.
The timeline will only show the items for the active component.
Isolate
Use Isolate to turn off visibility of all other components.
GROUP
Rigid Group
For imported subassemblies that are static. This will “glue” together sub-assemblies that have no motion required.
Include all child components.
You can now Move the parent component and the child components will go with it.
Timeline Group
Group timeline items into logical, and collapsible nodes
Enjoy!
Very helpful post!
I can see I've violated some best practices already when creating the assembly for this lamp.
All my sketches are on the top level and you mention it is better to activate a component before modifying it as sketches then will be created in/under that component.
As I cannot do that anymore, how do I move a sketch from the top level into a component in a subassembly ?
I tried simply dragging it onto the component but nothing happened that did not work.
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
Omar Tan
Malaysia
