Pointing Devices and Displays
New Member
greenbrown
Message 1 of 3 (1,189 Views)
mouse jumping around screen
1189 Views, 2 Replies
05-26-2010 02:48 AM
I am using AutoCAD mechanical and the mouse is jumping around the screen in the display area only. Is there a setting I can use to correct this problem. I have no problems in other programs or when selecting items from the AutoCAD ribbon.
*Dean Saadallah
Message 2 of 3 (1,189 Views)
Re: mouse jumping around screen
05-28-2010 06:03 AM in reply to: greenbrown
video card? driver? mouse driver? Windows OS? RAM? SNAP off?
Dean Saadallah
http://LTisACAD.blogspot.com
New Member
jomica
Message 3 of 3 (1,189 Views)
05-28-2010 07:41 AM in reply to: greenbrown
Do you have the Mouse "Pointer Trails On" ??
By turnning them off, solved the same problem I had.
Try
Good luck
