Pointing Devices and Displays
Member
rickrob
Message 1 of 5 (1,006 Views)
Logitech M305 mouse & middle wheel. AutoCAD2011 LT. Mouse wheel PAN function.
1006 Views, 4 Replies
03-19-2012 11:04 AM
Been using Logitech M305 for over a year.  With AutoCAD 2011, middle wheel... when pressed does not PAN. Checked with Logitech.  Ran tests & middle wheel works fine on web page, scrolling up and down.  When in AutoCAD, I've entered the mbuttonpan and set to "1".  When wheel is pressed straight down, crosshairs stay with no change.   I don't know what else to do.  Been using this mouse for over an year with no problems.  Have fast track project and need help please!
New Member
bagg68
Message 2 of 5 (997 Views)
Re: Logitech M305 mouse & middle wheel. AutoCAD2011 LT. Mouse wheel PAN fu
03-19-2012 08:36 PM in reply to: rickrob
I have the same problem with the M305 and Maya 2011.  Middle mouse click does not pan.  I'm just going to get another mouse.
New Member
bagg68
Message 3 of 5 (998 Views)
03-19-2012 08:48 PM in reply to: rickrob
Solved:
1. Download the SetPoint app from Logitech's site.
2. In the SetPoint utility, under Button Settings -> Select Button, Make sure item 3 is set to "Generic Button"
That did it for me!  Didn't even have to relaunch Autodesk Maya.
Charles_Shade
Message 4 of 5 (993 Views)
03-20-2012 04:44 AM in reply to: bagg68
OP - If this works for you please mark as Solved.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Member
rickrob
Message 5 of 5 (978 Views)
03-21-2012 03:45 PM in reply to: rickrob
Seems as though Logitech has changed their options as well as selections on what you can do with the wheel.  I tried somehting that I thought would not work... I selected for button 3 "Middle Button", clicked apply and OK, it worked.  It is only in the new revision.  I hate changes...
Rickrob
