AutoCAD Forum
Help with MEASURE command required
4 REPLIES 4
ElconGroup
378 Views, 4 Replies
I have DWG Trueview 2015 installed on Windows 8.1. Everything appears to work very similarly to my previous Trueview,however the measuring tool does not provide any measurement data when used. In my previous Trueview, on second clicking say for a linear dimension, a tab would come up with the distance stated. When I do this on my installed Trueview 2015, I get nothing. I have tried it on areas and volumes and it's just the same - nothing. How do I get it to show the measurement data ? What am I doing wrong ? As someone who calculates quantities from drawings, Trueview is brilliant for me as I have no AutoCAD training, however it's pretty useless if I cannot get the measuring tool to work.
Help please !
Ted Whitfield
Essex, UK
4 REPLIES 4
pendean
in reply to: ElconGroup
DTV2014 is still available, get it instead. It works.
mmhill
in reply to: pendean
Is this really the only answer???
Does Autodesk plan on supporting the measure command in DWG TrueView?
pendean
in reply to: mmhill
No idea, no one here works for Autodesk.
mmhill
Kinda hoping someone at Autodesk would respond...
”Boost
