I found and have the add-in for Navisworks 2015,where do I find the download/install for Revit 2015? Is it a available for 2014 as well?
Solved by DarrenP. Go to Solution.
its all the same install
there isn't a separate download/install for each product
the 2015 install works with 2011-2015 products according to the system requirements page
http://www.autodesk.com/products/point-layout/system-requirements
DarrenP
My bad, I had reveiwed and tested the add in via Navisworks but not Revit so I didn't realize it added their as well. Thanks!
