Point Layout Forum
Welcome to Autodesk’s Point Layout Forums. Share your knowledge, ask questions, and explore popular Point Layout topics.
How to add just one point to the Top Center of Concrete Insert?
0 REPLIES 0
Message 1 of 1
anil_mistry
605 Views, 0 Replies
  • Open the Drawing in ACAD
If you are not able to view fabricated object when you first open the drawing, Make sure you have object enabler installed. You can get “CADmep” object enabler from Autodesk by clicking on the link below:
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-fabrication-...
  • Isolate Layer for the object
  • Right Click on the screen anywhere and Select “Point Layout” then select “Add Selection Points”
  • Fill out appropriate field
  • Click “OK”
  • Select all the Objects or Select one you want to add points
  • Once you are done selecting click “Enter”
  • Click on “Top Center” for this exercise. (You can choose any option based on your selection Point Layout will put Point on the object).
Anil Mistry
Technical Support Specialist
0 REPLIES 0
