Is there a way to change the "point" block in autocad?
Solved by zach.crumal. Go to Solution.
Hi, yes you can select the point block itself, right click and go to the Block Editor. Once the block is opened in the editor, you can change text, font, format etc. Save changes and reload the block into your project. Please let us know if there are any further questions. Thank you,
Do note that you do not want to mess with the attributes, or if creating your own block, make sure the attributes are replicated exactly.
Shayne
The goal is different symbols for different systems. So we would probably only make changes to the "geometry" of the block.
