Description
When browsing the field list in a workspace or on the grid view it is hard to determine whether a field is a 'required' field. I personally find this particular parameter for a field as an important one to identify quickly.
Impact
Not having this simple enhancement, makes the checking process of required fields a little longer by then having to enter the field editing view to determine it's required state.
Severity
Low
Solution
Simply add * to the fields in the field list in the same way as they are seen to the end user.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
