In the Attachments tab I can add a Description when uploading a new file. That file can then be checked out and when checked back in a new Description can be entered. I like to use the Description field as a comments field to give some context to the particular version of the file being uploaded.
To view previous versions of the file I then click on the History button. However, the only details available are Version #, File Name, Date, and User. I would like to also have the ability to see the Descriptions of the previous versions.
Thanks.
Joe Hendrickson
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
