Use escalation to run script at fixed intervals
It could be handy if the escalation feature in the workflow can be used to run a script at fixed interval.
For example, send a weekly status report.
This could be as simple as just adding a checkbox in the escalation dialog to select 'REPEAT'. Then the escalation script will run every 'n' days.
Also, script run frequency could be reduced if the next run date could be selected based on a FIELD value (type DATE).
If there is a way to do this already, i.e. run scripts at fixed interval, please let me know.
4 Comments
nguyentru
Status changed to: Accepted
Hi Sten, This is a good idea. Many customers have approached me with similar requests. We will add this to our feature list. thank you, Trung
benderk
Hello -
Thank you for submitting your idea.  The timing isn't quite right for this to be a priority for development consideration.  As such, we will put this on the back-burner to revisit at a later date.  Please continue to comment and add your support.
Keri Bender | Global GTM Business Strategy Manager, Product Lifecycle Management
benderk
Thank you for submitting your idea. Have you tried the Modern Interface lately? We request that you review your idea in the context of the Modern interface. If your idea is not addressed, we invite you to create a new Idea in the context of Modern so that it can be addressed accordingly. Sincerely, Keri Bender | Global GTM Business Strategy Manager, Product Lifecycle Management
benderk
Status changed to: Archived
