SOmetimes you want to add a new field or change an existing field for all the records in a WS. If there are hundreds of records, this is a tedious task. It would be great to be able to run a report to export the desired records to Excel. Then you can easily edit the Excel file to add or chnage the fields. Finally, you would import this Excel file and update the WS. Currently, the import won't work if the record exists so you have to purge the WS and import to create new records. This is not ideal if you have other workspaces and records linked to the records you need to update.
I'd like to see the ability in the import tool to check a box to check if a record already exists, then just update it.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
