We need access via the Server Side Sripting to both the BOM Tab & Sourcing Tab.
I believe there are several support threads as well as Ideastation references to this functionality but I felt we needed a clear Idea Post for this functionality.
Similar to the new object record item.workflowitems recently added we need to have information contained in the BOM & Sourcing tabs for use in scripting.
An example would be having an assembly shown on an Sakes Quote Grid and a workflow that would explode the BOM children of that assembly into the grid of an RFQ and access the default supplier to create a master RFQ for cloning quoting purposes.
Ideally this would be read/write access for back feed updating of costing etc.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
