It would be the coolest thing ever to see the rest of the transition properties on the Workflow Summary Panel. When you have 73 transitions like I do It would save a lot of time to be able to see which scripts were tied to each transition, or to make sure that there is a script tied to the transition.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
