I'd like the ability to run a script by pushing abutton in the workspace item and not have to rely upon a state transition to do so. There are times where I want to create an item but use data from an existing item (the one I'm in at that time) and then link them together via the relationships tab. I want to do this without a state change (because state change would not be needed to simply link to items). I realize I can change behaviors to run a script upon creation that could do much of the same. It just makes sense to NOT to have to navigate away from where I'm at and then remeber what I want to link to. I'm all about automation.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
