hello,
as sometimes we have to have the Workflow Transition to be finished before being able to "play" with item created within Action Script (Add item to BOM etc...), could it be possible to have some step that are acting as robot... it means that it should launch a scipt when this "robot" script is reached...
in case of failure, we can either cancel previous Transition or if successfull, force next Transition to go to the next "manual" Step...
Best regards
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
