(As posted in the Help Forum):
I really like the feature to be able to create subsets of a Workspace picklist by setting the filter function in set-up. However I understand it currently only allows for AND combinations not OR ones.
I want to create a picklist that covers 2 types of employees coded as PM or PD in their job title field. An employee in these groups can only have one of these codes. At present the filter seems to read as though it is set to filter people who have PM AND PD in their job title field - which will never happen.
However, the field where I want to use the picklist, needs to be able to select either a PM or a PD depending on how a certain project is being run. As far as I can see, the other workaround - which would be to create a pre-filtered picklist for PMs and a separate pre-filtered picklist for PDs - can't work because a field can only be set to use one picklist at a time and not a combination.
If you can get this developed, it would be brilliantly useful all over our tenant.
Fiona
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
