Share ideas for future product features directly with the Fusion Manage (formerly Fusion 360 Manage) team and collaborate on existing suggestions with your peers.
Show only
Search instead for
If I change the pivot value in Work Space A is not updated in Work Space B until I actually change the derived field into another value. The derived field will change but the pivot wont.
I would like that the pivot value updates as the derived value does
What I'm trying to do is data integration. That the data that I have in the work space A be the same that I have as a derived field in the work space B. And if I change in WS A, changes in WS B. This shouldn't be static.
This is part of the feature spec for derived fields, that is to provide options on how changes propagate. The currently functionality is defined that updates are only performed on explicit update/edit by the user. There are plans to add additional functionality to allow updates to propagate without user action. I'll add this idea Station request to our feature requirements to make sure this behavior is covered correctly.
