Currently the Multiselect Picklist type is only available for the Item Details & Grid Tabs.
Not only would it standardize the picklist types across the tabs but give added functionality to use those tabs.
An Example would be for the RFQ workspace.
You have a list of parts that are added to the managed items tab from multiple workspaces (electrical parts, hydraulic parts etc.). You can have a multiselect picklist for each row that lists the vendors you would want to have quote on those parts. Your workflow would be:
Create Master RFQ -> Define parts & Vendors (managed Items) -> Request Quote (Spawn new RFQ's for each vendor selected in the multiselect picklist)
Currently this is possible in the grid tab, but the item field can only pull from one workspace whereas the managed items tab can pull from multiple based on the relationships defined.
BD
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
