More Custom Print Capability
Previously I was able to create a custom print/form in 360 and it worked well enough BUT I could have used more functionality.
I would prefer to be able to use a scanned document as the basis of my custom print. In that custom print I want to overlay the desired fields in the correct spacial location on the scanned document. In usage within an item I want a particupant to see the document directly an enter in the required feilds as needed (error checking and all). This is the same workflow as filling in a PDF file but instead it would 360-matized.
6 Comments
broepke
Although you can't add a scanned form you can design on in MS word and use that as a starting point (or if you have one already)  Check out the latest blog post
http://underthehood-autodesk.typepad.com/blog/2012/08/tip-tuesday-getting-even-more-advanced-with-ad...
Thanks for the response.
I am aware that I can do this with a Word doc. (and have used the functionality).
Specifically I need to do this with a scanned doc or PDF i.e. I need to fill out a government regulatory document as part of my process and I only have access to a TIFF or PDF file. Using existing functionality I would need to make a Word doc equivelant - less than ideal.
Again, thanks for the tip.
jared.sund
This is an interesting issue...  The problem I see here is that any sort of scanned image would be raster form, which is not very usable to align labels, image, tags, etc.  I think your request makes total sense, but we'll have to think about this one a little...
Taking the scanned image and making the background image for the report would not be diffictult (infact, I'm pretty sure you could do this today).  The hard part will certainly be the alignment issues...
jared.sund
I'm going to move this down in the list for now.
benderk
Thank you for submitting your idea. Have you tried the Modern Interface lately? We request that you review your idea in the context of the Modern interface. If your idea is not addressed, we invite you to create a new Idea in the context of Modern so that it can be addressed accordingly. Sincerely, Keri Bender | Global GTM Business Strategy Manager, Product Lifecycle Management
benderk
Status changed to: Archived
