Our customers would like a way to format the Money field type to always show its value in a typical currency format like, $1,500,100.00.
Currently this field type only shows 1000000.00 format. I can add a UoM symbol of $ to the field but this shows as 1000000.00 ($). Neither of these formats are acceptable and are very hard to read, especially when dealing with large values. If a Money field is used it should automatically know to add the symbol, the commas, decimal depending upon your regional currency settings.
The Money field type should adhere to your Windows currency format settings or to a defined PLM 360 currency format settings. This would improve the UI display and make reading these fields much easier from a user perspective, thus improving there experience with the product.
I've attached an image of the current display
Thank you for consideration to this idea.
John
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
