because of lack abilities in REST API it would be nice to execute script through REST API.
Algorithm:
1. Administrator creates actions script.
2. User logins to PLM360 with REST API.
3. Code of integration tool sends command to PLM360. For example, "ExecuteScript". Additionally can be defined ItemID, WorkspaceID, etc as arguments of function.
Currently, the workaround I will use is execution of script on create or update events of item.
Best regards, Vladimir
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
