Current Scenario: In PLM360 if any script fails due to an error, error is logged to script error log. However no one is notified. You will not know if you are not actively looking at your scripts.
Idea: Provide configuration where PLM360 admin can setup their email ids and be notified when a script error. It should work as follows.
1) Admin should be able to set the email id to which all errors will be sent.
2) An email containing the details of the error like:
Script Name:
User ID:
Timestamp:
Error details:
Link to the item that failed.
Should be sent to the configured email.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
