It would be nice that when you're in the edit mode, if you happen to mistakenly hit the cancel tab instead of the save tab you would get a prompt such as "ARE YOU SURE YOU WANT TO EXIT WITHOUT SAVING?" This would eliminate the possibility of losing any and all work when simply hitting the cancel key.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
