Please can you add a function button to the section bar/title/header that allows in edit mode all information held within the section to be cleared. I have a product spec sheet that is segmented in to many sections. Several of these sections are set up to specifically pull derived data from other work spaces, however if an incorrect selection has been made you have to manually delete every entry in to each field, this can be quite tedious.
For example, we design light fittings, so my product specification card has a section specifically for lamp information. I have a workspace that holds all the data for each lamp in a separate workspace for each lamp.
In my product specification card within the lamp section, you select from a drop down the type of lamp included in the product. This selection then pulls relevant information from the lamp workspace record and populates the remaining fields within this section of the product spec card.
If I select for example a E14 lamp, other information from the derived fields are completed automatically, but if I want to change to E27, then I need to manually delete from each fields in the section the data pulled in.
If there was a clear section button on t e section bar/title/header, this would make changing data for the whole section much quicker and more user friendly.
Not everyone would need this function, and security may be an issue for some people, but this could be selected within the Roles and permissions like the UNDO button is turned on and off.
Here is an example of what would be good, clear section button shown on far right of the section bar.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
