Autodesk,
What are the chances that the Autodesk team could come up with a solution to change future Field Data Types and not lose all previous saved data.
I have come across this a number of times. I am wanting to keep the same data, but learning the system and its capabilities I have found more efficient ways to pull the data along. The current way is running a report and using an excel spreadsheet to re-populate the fields (which is a strenuous process, for me)
Respectfully,
Trevor L. Hill
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
