It would be a time saver to be able to configure a custom BOM view for the Flat view, Similar to the nested view. This could possibly be implemented with a checkbox for and Applies to Nested, Flat or Both.
We have set up custom BOM field that is used to trigger spawing of tasks to perform action on the item in the BOM Row, I.E. Generate an RFQ request where the item info is copied via script to the RFQ Record. The issue is that in the nested view the quantity shown is the unit quantity not the project rolled up quantity. To get that you need to switch to the flat view get the rolled up quantity and switch back to the nested view and enter the quantity to Request for Quote.
This is just one use case, but feel that functionality would make the BOM View for useful.
BD
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
