A use case came up to compare two BOMs using the flat version of the BOMs. Basically we are going to start importing quoted (flat) BOMs into PLM 360 to compare to the structured/level BOMs created in our custom configurator application. The team is looking a quick way to verify totals in PLM 360, exporting to excel is possible but sub-optimal. Ideally you would mimic the Nested Views and features for the flat view.
Matt
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
