Hi Everyone
I would really love some improvements from the advanced print view
1. I need a way of having global control over all print views. eg, if I have a company footer then I want to change It once and apply to all print views however this is just an example and It would be useful for a lot more then that.
2. I have created the print view I want in HTML and I have It looking the way I need It however It looks horrible when I put It into PLM 360, It appears that the HTML code used by PLM is very old and is not able to read CSS at all, even if It is embedded into the html code itself.
I really need this to be resolved, currently I am not able to create anything near professional enough to give to a client.
Attached is a screen shot of the report straight in Chrome, the other is what It looks like coming out of PLM. It will not take you long to work out which one is out of PLM.
Thanks Autodesk
James Tennent
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
