Description
The Advanced Print View has a number of issues with the formatting on the print.
Refer image below;
Green - Using the default format ${workspace.metadata.grid.title.value} shows the original tab name which is Grid. In this workspace the Grid tab name had been renamed. This is not showing the changed tab name.
Blue - Between grid rows, it is quite common to get gaps between grid lines.
Red - Grid rows are split between pages. The split row should be starting as a full row on the next page. Having these rows split across pages makes it harder to read.
Impact
Looks messy. Not professional enough to give to clients.
Severity
High
Solution
See if these issues can be improved for neatness.
Maybe rendering the Advanced Prints as HTML isn't the correct answer to this. Maybe the print should be converted to a PDF on the server-side in order to obtain correct formatting on the print, and then served to the client as a download, and/or the PDF displayed to the browser ready for viewing and then printing.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
