Images are some times needed as additional information to support text or data, it would be very benafitial if the Grid Tab could have the capability of adding an image field.
The Grid Tab is a great way of adding additional lines of information based around specific fields, this allows you to keep adding and adding more lines of the sames date where needed.
However you currently cant add images as one of these specific fields as image can not be picked from the data type dropdown when setting up the field.
I have a need for creating this type of tab within a workspace, but the information which is needed within this area of the workspace must have supporting images pr photos.
The advantage of having the information in this way then means you can progress to an advanced print view which can be printed out and given to the shop floor in form of a report if needed, in my case I want another user to look in to this workspace and on to the Grid tab to see the lines of information with supporting images to help overcome a language barrier.
Please can you look in to adding image fields in the Grid section.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
