One very interesting feature from NetSuite is the Field Help. Every field within every form/record is clickable and triggers a small pop up with a short help outline or instructions on how to access/modify. This field help can be configured by the admin for custom fields.
It would be great to add the capability to specify help and instructions on PLM 360 fields and would even allow clients to implement their processes within their workspaces and forms.
Thanks!
Julie Labrecque
ERP Guru
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
