Today I came up against a mystery error because I had a derived field that was supposed to be set to derive from a multi-select picklist, but the source was blank When I tried to reset it, the field I wanted would not show on the list as I now realise you can't have a derived field that could show more than one value (i.e. coming from a multi-select picklist).
Could you add this functionality if it is possible as that would be v useful to ensure data only has to be changed in one place, yet is consistent throughout the system ?
Many thanks,
Fiona
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
