How can I edit requirements set for performing a workflow transition? When I try to move an item to the next workflow state, I get an error (see attached) because a certain field is not populated. We no longer use this field, so I'd like to remove this requirement. Thanks!
Solved by broepke. Go to Solution.
Glad it did. I was answering on my phone the other day - wasn't sure if that was enough detail for you!
