PLM 360 General Discussion
390 Kudos
Post 1 of 9
Workflow editor Save error
164 Views, 8 Replies
09-25-2012 01:08 AM
I'm trying to recreate a workflow, I've purged all the items from the workspace. but I get the following error whenever I try to save it:
The only way I can save it is if I delete all the states.
I have tried deleting the transitions & states one by one but they all seem to be having the save effect & I can't save.
there aren't any scripts etc, & I have a generic permission setup for the transition. What could be causing this? My other workspace workflows seems to edit just fine.
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
Scott,
I'm unable to reproduce the error in my testing.  Can you try cloning that workspace and then recreate the workflow and let me know your results?
Thank you,
Product Support
12 Kudos
Post 2 of 9
Re: Workflow editor Save error
09-25-2012 05:20 AM in reply to: scottmoyse
Hi Scott,
I'll do some testing, see if I can duplicate this error and then get back to you.
John Hill
Support Specialist
Product Support
Product Support
12 Kudos
Post 3 of 9
09-25-2012 06:13 AM in reply to: JohnCHill
Scott,
Thank you,
John Hill
Support Specialist
Product Support
390 Kudos
Post 4 of 9
09-25-2012 02:06 PM in reply to: scottmoyse
Yes cloning it allowed me to create the workflow. So I had to delete the old one, but didn't transfer the roles first! Duh...
Cheers
Scott Moyse
Product Support
12 Kudos
Post 5 of 9
09-26-2012 05:08 AM in reply to: scottmoyse
Glad the Workflow is now operational for you.
Thanks for the post.
John
John Hill
Support Specialist
Product Support
Active Member
1 Kudo
Post 6 of 9
06-06-2013 06:30 AM in reply to: scottmoyse
I'm having this exact same issue this morning except my workspace is already in use so the option of cloning is not going to work. I tried recreating the issue in my sandbox and am unable to recreate it. How can I get this resolved?
Product Support
12 Kudos
Post 7 of 9
06-06-2013 07:11 AM in reply to: JJ
Please delete the states and transitions from your workflow producing the error and save it.   Then copy and paste the workflow from your sandbox.  Please let me know if you are then able to save your workflow.
John
John Hill
Support Specialist
Product Support
Active Member
1 Kudo
Post 8 of 9
06-06-2013 07:37 AM in reply to: JohnCHill
I'm afraid that didn't work and now I have no workflow at all. I tried just creating states and not copying them and I still have the same error.
Product Support
12 Kudos
Post 9 of 9
06-06-2013 07:56 AM in reply to: JJ
I've opened a support case for this issue and will be sending you email shortly.
John
John Hill
Support Specialist
Product Support
