I need help to figure why some users are getting this error when creating a new item.
This happens when they try to save the item. They were able to create new items before and all of the sudden now
they cannot.
They already tried to clear the browing cooking, reboot thier machine and they still keep getting this erros. They both tried it using IE9 and Chrome.
Can any one help?
Is it a workflow enabled workspace. if so are you using a script on the initial transition?
Are there any computed fields?
Create a an admin role on the workspace with all admin permissions assigned. Then check to see if the same issue appears.
I seem to remember having the same problem before but I can't remember all of the details of how it was solved. Sorry. I know it was related to something in the item details.
I would suggest that you try and isolate the field of section that is causing the issue in the item details. I
