I have installed Vault PLM sync.
I can config it, without problems. like the video from Wikihelp. The sync process is running,
I rebuild the history it works, an than all the jobs are in the job queue and nothing happens .
Publish to Buzzsaw works so the Job Server has no problems.
To change the wait time has no effect.
I work with German Vault 2013 Prof, latest Hotfixes. I can reproduce this on different Client PCs.
So is it a common problem? Or has someone an hint? Attached you see the related pictures.
Thanks Juergen
Juergen - I'll create a support case for this and have someone from our team work with you directly to resolve.
Michelle
Hi Juergen,
I'll work with you on this problem.I will contact you via your email.
Boris Chan
Product Support Specialist
Global Services
Autodesk, Inc.
the problem was, in my PLM workspace there were field from type paragraph an date.
After removing this fields it works.
Juergen
Thanks to Madhanagopal Thiruvenkatachalam, our PLM Support team member who worked with Jeurgen to identify and resolve this issue.
Boris Chan
Global Services
Autodesk, Inc.
