Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
v1 api and .NET
9 REPLIES 9
Message 1 of 10
mike.ponti
719 Views, 9 Replies
v1 api and .NET
I have an app that is currently using the v2 api and now that is never going to leave tech preview, I am moving things over to v1 api, but something weird is happening.
I have tried using fiddler and both RestSharp and HttpClient libraries to figure out what is going on.
I am able to successfully login to plm360 using the v1 api and get back a loginresponse object with the session id. Next I try to get the workspaces (api/rest/v1/workspaces). Using the HttpRequestMessage I can print out the contents of my request:
Method: GET, RequestUri: '/api/rest/v1/workspaces', Version: 1.1, Content: <null>, Headers:
accept: application/json
cookie: customer=ZZZZZZZZZZ;JSESSIONID=E01D15CAD6085AA0EC783XXXXXXXX1F0C.worker1
When I execute the request, I get internal server error (500). However, if I take the headers from above and execute the request in Fiddler, I get back the list of workspaces.
I get the same behavior in RestSharp.
Does anyone have an idea of what I am doing wrong??
Mike
9 REPLIES 9
Message 2 of 10
jared.sund
in reply to: mike.ponti
Hello Mike,
Below is a very basic C# class example that provides functions to log into PLM 360 and retireve a list of workspaces.  This is working with XML, but you could easily change it over to JSON.
Hope this helps,
-Jared
Basic usage of the class
public partial class Form1 : Form
        basicPLMV1 myPLM;
        public Form1()
            InitializeComponent();
            myPLM = new basicPLMV1("sometenantNameHere");
            label1.Text = "false";
        private void button1_Click(object sender, EventArgs e)
            label1.Text = myPLM.login("myusername", "mypassord").ToString();
        private void button2_Click(object sender, EventArgs e)
            XmlDocument results = myPLM.getWorksapces();
            textBox1.Text = results.OuterXml.ToString();
Sample Class
using System;
using System.Collections.Generic;
using System.IO;
using System.Linq;
using System.Net;
using System.Text;
using System.Threading.Tasks;
using System.Xml;
namespace sampleApp
    class basicPLMV1
        private string _tenantURI;
        private string _authCookie;
        private bool _loggedIN;
        public basicPLMV1(string tenantName)
            _tenantURI = String.Format("https://{0}.autodeskplm360.net/", tenantName);
            _loggedIN = false;
            _authCookie = "";
        public bool login(string userName, string password)
            string tenantURIinput = _tenantURI + "rest/auth/1/login.xml";
            string payload = String.Format ("<authCommand><userID>{0}</userID><password>{1}</password></authCommand>", userName, password );
            HttpWebResponse response = post(tenantURIinput, payload);
            XmlDocument xmlDoc = new XmlDocument();
            using (XmlReader reader = XmlReader.Create(response.GetResponseStream(), new XmlReaderSettings() { CloseInput = true }))
                xmlDoc.Load(reader);
            if (xmlDoc.DocumentElement.SelectSingleNode("/userAuthInfo/authStatus/id").InnerText == "200")
                _authCookie = response.Headers["Set-Cookie"];
                _loggedIN = true;
                return true;
            else
                _authCookie = "";
                _loggedIN = false;
                return false;
        }//end function login
        public XmlDocument getWorksapces()
            if (!_loggedIN) { return null; }
            HttpWebRequest request = getHTTPRequest(_tenantURI + "api/rest/v1/workspaces.xml", "GET");
            request.Headers.Add(HttpRequestHeader.Cookie, _authCookie);
            HttpWebResponse response = (HttpWebResponse)request.GetResponse();
            return xmlDoc;
        private HttpWebResponse post(string uri, string payload)
            XmlDocument doc = new XmlDocument();
            HttpWebRequest request = getHTTPRequest(uri, "POST");
            UTF8Encoding encoding = new UTF8Encoding();
            request.ContentLength = encoding.GetByteCount(payload);
            request.ContentType = "application/xml";
            using (Stream reqStream = request.GetRequestStream())
                reqStream.Write(encoding.GetBytes(payload), 0, encoding.GetByteCount(payload));
            return response;
        private HttpWebRequest getHTTPRequest(string uri, string method)
            HttpWebRequest request = (HttpWebRequest)WebRequest.Create(uri);
            request.Method = method;
            request.Accept = "application/xml";
            return request;
Jared Sund
Sr. Product Line Manager, Product Lifecycle Management
Autodesk, Inc.
Message 3 of 10
mike.ponti
in reply to: jared.sund
Thank you Jared, that was really helpful.
I am still unsure of one thing though ... when I was doing it manually in fiddler, the auth cookie looks much different but still works. Is that fiddler just filling in some missing items for me?
Thanks again,
Mike
Message 4 of 10
jared.sund
The auth cookie can look a little different each time you login.  It may or may not include load balancing information, depeding on how the system routes your session.  This could be the difference you're seeing.
-Jared
Jared Sund
Autodesk, Inc.
Message 5 of 10
Hello mike im trying to get a succesfull login with v1 api but im not able to authenticate I get a LOGIN_FAILED i believe i have domething missing in my authentication data or something
Tags (1)
Message 6 of 10
Hi Yader, LOGIN_FAILED sounds to me like invalid credentials or something else wrong with your POST to the login endpoint. I have always used json for my post data and the field names are all case sensitive so make sure your POST data matches what is in the api documentation (login api page). I assume that you have covered off all of the other basics:
  • correct url
  • you can login with your creds at the web portal
  • POST headers are set (you can see these on the link above)
Hope that helps a bit.
Message 7 of 10
Hello mike ,i appreciate your help.I did as the documentation says before I asked ,and after i re-checked but still not able to log-in, I believe that the 2 parameters I´ve sent by JSON are not enought ,I also checked the correctness of the password(I came to conclusion that is probably user/password related but still not logged),so im currently clueless,thanks for the help and will keep trying
Message 8 of 10
Hi Yader, according to the docs, you only post the user id and password when you do the api call (and is all that I supply on login). The only other thing I could suggest is that you make sure you clear out any default headers that are being included when you make your REST call. Sometimes the api can get confused if your headers are incorrect. I had this happen to me with downloading images using restsharp and I had it happen when using the rest libraries that are in the universal windows platform.
Good luck!
Message 9 of 10
Hello Mike ,this is the code of my rest function.I supplied the headers(i believe) and the paramenters
,maybe from here you get a clear idea.It should be straight forward but the strange thing is the response,
that it behave like the authentication is incorrect,but i tested on the web my credentials
function
login(url, postMethod) {
item.EXTERNAL_DATA = "";
var xmlhttp = getHTTPObject();
xmlhttp.open(postMethod, url, true);
xmlhttp.setRequestHeader("Content-type", "application/json");
xmlhttp.setRequestHeader("Accept", "application/json");
var parameters = {
"userID": "t_a360user",
"password": "p"55w0rd"
try {
xmlhttp.send(JSON.stringify(parameters));
item.EXTERNAL_DATA = xmlhttp.responseText;
catch (err) {
item.EXTERNAL_DATA = err.message;
Message 10 of 10
The only thing that looks funny in what you posted is how the password is being shown. Perhaps that isn't serializing properly. Try changing your password to something else and see if that helps.
I am not as familiar with the javascript libraries so not sure if the one you are using has some default header properties that need to be cleared first.
