Fusion Manage Forum
Welcome to Autodeskā€™s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Showing results forĀ
Did you mean:Ā
Users, ALL by Name, pick list
6 REPLIES 6
tray1
969 Views, 6 Replies
I'm using the
Users, ALL by Name pick list to get list of current users. once I have selected one user how would I go about getting that persons email address?
6 REPLIES 6
bastien.mazeran
in reply to: tray1
Hi Tim,
This will require a behavior script.
You could use the Javascript split function to "split" your username selection in your picklist into two strings for firstName and lastName.
var selectedUser = item.USER_PL.split(", ");
From there you could construct a new user properties object, and set firstName and lastName as properties.
Then pass that user properties object to the Security.searchUsers() method and retrieve a new user object.
Finally set your email field to the email property found on your user object.
I hope this helps.
Bastien Mazeran
Technical Support Specialist
tray1
in reply to: bastien.mazeran
Great Help thanks, I didn't think it would be as involved as that.
I'll let you know how I get on.
jpiggee
in reply to: tray1
Hi Tim,
I actually had the same question asked of me earlier so I figured I would share the full solution.
****Note: ****
This is based on a multi pick list and a scenario of 2 users with the same first and last name.
Solution:
var userName=item.APPROVALS_REQUIRED; // Get the users
var nameArray=userName[0].split(", "); // Split the name of user in question
var lName=nameArray[0]; // Last name
var fName=nameArray[1]; // First name
var userInfo=Security.searchUsers({lastName:lName, firstName:fName}); //find the user
var userEmail=userInfo[0].email; //return email of user in question
Joseph Piggee
Fusion 360 Administrator
TPI Composites
jpiggee@tpicomposites.com
tray1
in reply to: jpiggee
HI Joe,
With a little help this is what I ended up with.
var selectedUser = item.ENGINEER.split(", ");
var user = Security.searchUsers({ lastName: selectedUser[0], firstName: selectedUser[1] });
if (!item.ENGINEER_EMAIL) {
//println(user[0].email);
item.ENGINEER_EMAIL = user[0].email;
jpiggee
in reply to: tray1
Tim,
Nice solution as well.
Joseph Piggee
TPI Composites
BiggePLM
Tim and Joe,
Nice solution and thank you,
Great example of the new Security.searchUser function.
This along with pre-filtered picklist will make for many many options for workflow and notification assignments and checking with some inteligence to the options presented to the users
Much more useful
Thanks again.
Bob D
