PLM 360 General Discussion
dkeeley
Message 1 of 10 (226 Views)
User email address in scripting
226 Views, 9 Replies
12-02-2012 03:07 PM
I have a script that needs to be able to access a user's email address to send an email. I'm having trouble working out the script to access this user item data.
So far I have something like this;
var user = item.TEAM[0];
var user_details = Security.loadUser(user);
var test = user_details.email;
The online help has something like this but I cant seem to work out how to use it correctly;
var users = Security.listUsersInGroup('Quality');
for(var index in users) {
  email.to = users[index].email;
  email.send();
Product Support
michelle.stone
Message 2 of 10 (219 Views)
Re: User email address in scripting
12-02-2012 05:32 PM in reply to: dkeeley
I've done a couple blogs with email examples - see if either of these get you what you need:
E-mail for the Masses
Postal Service
Hope that helps!
Michelle
Michelle Stone
PLM Product Manager
dkeeley
Message 3 of 10 (205 Views)
12-03-2012 06:32 AM in reply to: dkeeley
Hi Michelle,
I'm still having problems. Can you tell me how to extract the email address from a user that has been selected from a picklist?
David.
Product Support
michelle.stone
Message 4 of 10 (194 Views)
12-03-2012 11:46 AM in reply to: dkeeley
Another example!  Here's a picklist set up to all users and the script I use to send to whomever is selected.
Script:
Hope that helps!
Michelle
Michelle Stone
PLM Product Manager
dkeeley
Message 5 of 10 (191 Views)
12-03-2012 01:34 PM in reply to: michelle.stone
Hi Michelle,
Thanks for the info. I think I can see what the problem is now.
If I'm correct the 'User, ALL' picklist contains user ids. That way you can access the email address using the Security.loaduser formula.
But I don't seem to have that picklist. I have a picklist called 'Users, ALL by Name' which returns the name of the user - not the id. So I don't think you can use Security.loaduser on a user's full name - you need the userid.
How can I go about replicating the 'User, ALL' picklist that you have shown in your screenshot?
David.
dkeeley
Message 6 of 10 (188 Views)
12-03-2012 02:31 PM in reply to: dkeeley
Hi Michelle,
I have just tested my theory and I believe I am correct. You can see in the attached image that the email address is recovered correctly if I use a username (not the user's name). So to solve this issue I need to be able to do one of two things;
1. Create a user picklist that returns username (e.g. dkeeley) NOT the user name (e.g. David Keeley)
2. Find a way to get the email address from a user name.
In the meantime I've written the following script to do it (but its dependant on all usernames being in the same format);
var i = 0;
var team_size = item.TEAM.length;
var email = new Email();
email.subject = 'Comment Added to Special Project '  +item.NUMBER;
email.body = getPrintView('Project Comment Email');
while (i<team_size)
    var user_name = item.TEAM[i];
    var user_name_length = user_name.length;
    var char_position = user_name.indexOf(',');
    var letter = user_name.charAt(char_position + 2);
    var user_surname = user_name.substring(0,char_position);
    var user_id_temp = letter + user_surname;
    var user_id = user_id_temp.toLowerCase();
    var user_details = Security.loadUser(user_id);
    i++;
    email.to = user_details.email;
    email.send();
Product Support
michelle.stone
Message 7 of 10 (186 Views)
12-03-2012 02:53 PM in reply to: dkeeley
Sorry David - that was a wicked old example I posted, but looks like you got it sorted out!  Another example for extracting the user info from the picklist result (assuming you name the field PLM360_USER_NAME:
var user= item.PLM360_USER_NAME;
var securityInfo=Security.loadUser(user);
item.FIRST_NAME=securityInfo.firstName;
item.LAST_NAME=securityInfo.lastName;
item.TITLE=securityInfo.title;
item.MAIL=securityInfo.email;
item.ORGANIZATION=securityInfo.organization;
Thanks!
Michelle
Michelle Stone
PLM Product Manager
dkeeley
Message 8 of 10 (182 Views)
12-03-2012 03:52 PM in reply to: dkeeley
Hi Michelle,
The problem with this as I understand it is that for me the item.PLM360_USER_NAME = 'Keeley, David' NOT 'dkeeley'. The former value is not the userid so cannot be used to load user information.
I need a way to get the userid 'dkeeley' from the user name 'Keeley, David' OR I need to modify the picklist to return the userid instead of the user name.
Any thoughts?
David.
Product Support
michelle.stone
Message 9 of 10 (170 Views)
12-04-2012 11:18 AM in reply to: dkeeley
David - there currently isn't a way to get the userid from a picklist, but they are working on it.
Michelle Stone
PLM Product Manager
dkeeley
Message 10 of 10 (160 Views)
12-06-2012 09:47 AM in reply to: dkeeley
Thanks for your help Michelle.
