Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Trying to add BOM to item using REST API
2 REPLIES 2
chocolate_ali
640 Views, 2 Replies
I am trying to add a BOM to an item in PLM 360 through the REST API. I can successfully add an item in and read a BOM, but when I try to add the BOM I get "Internal Server error 500" returned. I am querying the /api/rest/v1/workspaces/{workspaceID}/items/{DMSID}/boms endpoint. The BOM i'm sending is below:
"{"list":{"data":[{"bom_item":{"dmsID":5827,"workspaceType":1,"workspaceID":113,"bomDepthLevel":1,"quantity":1.0,"formattedQuantity":"1","descriptor":null,"revision":null,"itemNumber":0,"assembly":false,"cost":0.0,"isPinned":false,"quoteID":0,"isUsingDefaultQuote":false,"leaf":false,"redlinedCost":0.0,"redlineAddition":false,"redlineAgainstVersion":0,"redlineDeletion":false,"totalWeight":0.0,"lifecycleStatus":null,"hasSourcing":false,"hasRedlinedSourcing":false,"fields":null}},{"bom_item":{"dmsID":5832,"workspaceType":1,"workspaceID":113,"bomDepthLevel":1,"quantity":1.0,"formattedQuantity":"1","descriptor":null,"revision":null,"itemNumber":0,"assembly":false,"cost":0.0,"isPinned":false,"quoteID":0,"isUsingDefaultQuote":false,"leaf":false,"redlinedCost":0.0,"redlineAddition":false,"redlineAgainstVersion":0,"redlineDeletion":false,"totalWeight":0.0,"lifecycleStatus":null,"hasSourcing":false,"hasRedlinedSourcing":false,"fields":null}}]}}"
Has anyone succuessfully added a BOM to an item in PLM?
2 REPLIES 2
dahalb
in reply to: chocolate_ali
The BOM endpoint is limited doesn't accept all the columns of a bom table.
It also accepts collection of bom objects that have three fields: bomDmsID, itemNumber and itemQuantity.
Here is a an example of a payload:
[  { "bomDmsID":123, "itemNumber":100, "itemQuantity": 2},
{ "bomDmsID":456, "itemNumber":200, "itemQuantity": 3},
{ "bomDmsID":789, "itemNumber":300, "itemQuantity": 2}  ]
Note that it doesn't recognize other fields such as: bomDepthLevel, redline*, has*..etc other than the three mentioned above
chocolate_ali
in reply to: dahalb
Thanks that works perfectly!
